DVD conversion
tinpanalley
1,515
25
For DVD VOB file content converted to MPG without loss of quality in video or audio, is Handbrake the best tool? I used to use vob2dvd ages ago but it won't run on Windows 10. :)
shortylickens
80,287
17,082
GOOD QUESTION!
I was just ripping some DVD's to my 10 TB drive and realized it would be better to convert them. I also use Windows 10.
tinpanalley
1,515
25
GOOD QUESTION!
I think Handbrake may be the most efficient way. I just did it, I just need to confirm whether I'm doing a 1:1, no quality loss conversion.
TheELF
4,029
753
Use avidemux to load the main .ifo file, set video and audio to copy and save the file,that's the only way to get lossless to copy the stream.
Reactions: tinpanalley
tinpanalley
1,515
25
Oh, really? Ok, see, I knew there was a way with avidemux or virtualdub or something. Thank you!
tinpanalley
1,515
25
Hmmm... unfortunately got a "cannot find a demuxer for ... *.IFO" error.
Also, do you happen to know off hand what the options would be to ensure a 1:1 uncompressed copy?
Bardock
346
39
Vob files are mpegs no need to remux. Copy vob files to mpeg like this in Windows command prompt:
Copy /B part1.vob + part2.vob "name of movie.mpg"
And it will merge them lossless.
tinpanalley
1,515
25
Surely there's a GUI method, though. Without going to DOS.
Bardock
346
39
Lol maybe but give it a whirl it's fast and easy, I do it all the time with .ts files and it works.
tinpanalley
1,515
25
Well, that's good to know, because NOTHING seems to work when converting .ts files. I just want a program that can do a 1:1 copy (understanding that most DVDs are compressed anyway) and then do some further compression should I need to in the same program.
Bardock
346
39
Use the converter in vlc then. It uses same libs as ffmpeg but is easy gui.
Go to convert
Load vob file
Select a profile that is the format you want or make your own
Select destination
Convert
It's easy but slow.
jkauff
583
13
I rip DVDs using makeMKV. gives lots of control over extras, audio tracks, subtitles, etc and is quite fast.
Agree 100%, but make sure your playback device can handle .mkv files, or you'll have to go another step and extract the content from the container. My Smart TV handles .mkv, but some older models don't. And of course, no Apple products support .mkv.
