DVD/CD RW drive does not recognize blank CD-R discs
billsco11
My Dell Dimension E510 DVD/CD RW drive no longer recognizes blank CD-R discs, so I can no longer burn audio CDs. The drive did function in this capacity in the past.
I've already uninstalled/reinstalled the drive in Windows along with checking the status of IMAPI to ensure Windows was set up correctly.
Any other suggestions on how to fix this? I'd prefer not to buy a new RW drive.
Thanks
Bill
JustaGeek
2,827
Try cleaning it with the air, and if that does not help, get the 'Cleaning CD/DVD" at CompUSA.
If that does not help, get a new one - they're only about $20 - $25 on Newegg, or about $30 for the DVD burner.
Good luck!
klopas
18
I'm having problems with this too. I have a Pioneer 112D and Plextor PX-712A and neither recognized CD-R's after I upgraded my system. Now all I can burn are DVD. Any other suggestions? Thanks...
Rottie
4,795
If it is under warranty then have no fear....call Dell Tech Support they love to help you with problems
Roguestar
6,045
The CD-burning part may have broken. Check it still reads CDs, and if under warranty call them up as Rottie suggested. Otherwise get yourself a multi-layer multi-format multi-thing multiburner DVD drive for $25.
