DVD Audio Problem! Please help!
GoingUp
I burned a DVD, and it plays just fine in my computer with audio, but when I play it in my PS2, I get no audio. Normal movies have audio, and games do as well. I captured a soccer game on DVD today with my All in Wonder 9700, and I burned it using Nero. I get picture on the TV, just no sound....
Ideas?
Now that I am playin it in my computer, the audio changes pitch frequently so that it sounds like the announcers are chimpmunks.... ideas? :|
When I play one of the VOB files in Windows Media player, the audio sounds normal... ideas what the heck is wrong?
I have had similar problems when burning disks as well. Had to redo the VOB files. I have always had the best luck with sound when I captured to a .wav files and the converted to .mp2, .mpa or which ever your particular software uses.
I reauthored the DVD twice with no success. I brought the DVD in to work, and it plays just fine on the systems here at work.... ggrrrrrr
I captured a live soccer game, so I don't know what else to do...
I also have a larger mp2 of another game, so I will try to convert that tonite and then burn it and see what happens....
Could it be that the file that is captured is ended in mp2 ? Then I just rename it to mpg and demultiplex it.... do I need to rerender it?
Another thing is, that when I capture at vcd quality, which is half the resolution, I think it looks better on my tv for some reason.... am I crazy ?
The only other thing I can think of is to try different brand of media.
the file is recorded as an MP2 file... video and audio both are included.... how do I make a dvd player compliant dvd out of my capture?
