Originally posted by: virtualgames0
I've always used nero recode. Easy to use and it works great.
Nah forget that, I've already learned that using DVD Rebuilder with CCE, there is nothing better, even with HC it's good too.
Personally I don't get why people mess with anything else, oh well to bad for them.
Originally posted by: ta8689
ok, how do u use drd rb and cce???? i downloaded them both and just got an error when i tried to do anything
Oh yes, you're so l337 for using that program that takes 3 years to master :roll:
BTW, have you even tried using nero recode before?
Sometimes it's not worth going through hours of hassle just for a near negligible difference in quality.
If it takes you 3 years to figure out how to use a program as simple as DVDRB,
I can only assume that your parents dropped you on your head repeatedly or you have some sort of learning disability. The author of DVDRB's whole intent when writing the program was to create a front end for professional encoders that made them as easy to use as the one click consumer DVD copying programs. And he succeeded in doing just that. 5 minutes of perusing one of the myriad of guides available for DVDRB and youll be good to go. And the difference is quality is hardly negligible.
Hard to say, Theres a million guides out there. Find a good one to help you. CCE isnt for people who just want a 1 click quick backup program. Its a professional program that yeilds the best possible software based quality. It actually takes some experience and time.
I dont use rebuilder myself, so I couldnt really help ya with that. I do everything old school with just scripts and CCE alone. But its taken me 3 years to get as good as I am with it. Just find a good guide and follow it. It isnt that difficult using rebuilder. You should try it by hand, with just scripts and see how difficult it is to learn.
