Hi,
I'm in the process of defining a better setup for capture my DV movies, straight to uncompressed AVI files, for latter edition and DVD burn.
First of all, my setup:
Camcorder: Sony DCR-HC85E
Computer:
Processor: P4 2.4c
Memory: 1Gb (2x512Mb)
Graphic Card: Gicacube ATI 9600Pro VIVO 128Mb (used for analogue capture)
I have a tower with a front Firewire connector, so accessing the plug is really easy: Tower Firewire front-connector
To make the trick of capturing, I'm using Adobe Premiere Pro 1.5 (lattest version). It's great, I can even command the camcorder operation within this software 😉.
So the only thing missing, was in fact the firewire cable, since sony doesn't give any bonus, unless you pay for them 🙁.
So, I entered my local store, and they sold me a this Bandridge cable.
I got home, connected, and start capturing with no problem at all. Then I start thinking about quality ... I think the quality I'm getting is okay, but I want the BEST! So, I went again to the store, and they presented me with a beautifull gold plated firewire cable, this Profigold cable. It costed me 3 time more, so I hopped it would be worth it ... 😉
I got home, and start capturing, again with no problem at all. So problems aside, it's time to check the quality ... and in this area I got quite a surprise ... the quality feels exactly the same! Damn! Something must be wrong, since I really believe there is quite a quality difference between Bandridge and Profigold.
Then I thought about the obvious ... my Tower firewire connector is NOT gold plated, and it's directly connected to my motherboard using the usual thin wires ... and in this area I need your opinion ...
Should the problem be with that front connector plug, which degrates quality qhen receiving and transmiting the signal to the motherboard? Or that should not be the problem at all?
If so, how could I solve the problem? I thought about 2 solutions (first one would be better, if available):
[1] A front pannel for the tower (to a 3 1/2" bay, or even 5 1/4" bay), which has gold firewire plug, and apropriate wire to transmit the signal without loss to the motherboard (I would still have the advantage of a front case connection, no need to crawl under my desk);
[2] A PCI card with gold firewire connectors, which would get the signal without loss (can it bring any incompatibility with my system? I don't have experience with firewire PCI cards).
In any of those last 2 solutions, what is your opinion? What brands/products you recommend for solution?
(I also capture video from analogue sources, in this case I have a VHS VCR connected to my ATI VIVO S-Video, using a Profigold SCART->S-Video connector, so I guess I'm okay, since I'm connecting directly to the capture card, don't you think?)
Thank you.
Computer:
Processor: P4 2.4c
Thank you.
