Ok im bascially wanting to record to my PC from a camcorder and can't decide on what to get.
The two main options i see are the expensive DV cams that come with firewire for streaming to the hard drive.
The cheaper option seems to be to go with a a hi 8 camera, that uses a tape but is very high quality obviously not digital though. in this scenario i would obviously need a video capture card.
I guess my question is, with a DV cam coming in around $200 -- $250 more than the hi 8 cam. Is it worth it, or is the quality im likely to get from a reasonable quality vid capture card comparable anyway.....
If so i allready have a decent graphics card and don't really want to replace that as such, are there any good affordable TV capture cards for what im wanting that don't use the graphics card.... any advice you can give will be much appreciated and general opinions are welcome too.
Most of the shots are likely to be indoor shots if that makes a difference
