Dust and Heat
philosofool
283
19
So, I'm probably about to tell you something you already know. But maybe some people don't, so here goes.
About three years ago I got an inexpensive after market CPU heatsink and fan to replace the swarm of mosquitoes that intel included with my core i5 750. I was specifically interested in a quiet cooler with acceptable performance, since I'm not an OC'er. I was extremely pleased by both the silence and performance on the new cooler (a SilenX model something or other.)
However, recently I had noticed my CPU temps getting pretty out of control. I was running in the high 70s and low 80s in Prime95 heat tests and even reaching those numbers while gaming. Today, I had a problem with my video and, fearing the best, immediately checked to see if the card had failed (failed card = excuse to replace 3 year-old card!), but allas, the cord had just pulled loose. Anyway, I noticed with the case open what I would call a ton of dust on the CPU heat sink. It occurred to me that there was enough dust to inhibit airflow over my heatsink, so I vacuumed it off.
Result: my CPU is now at 69-71 in Prime95.
Charlie98
6,298
64
Dust is evil... Not only will it clog up the exchanger fins on a cooler, but gum up fan blades, making them less efficient.
My house is extremely dusty and I finally had to swap into a case with built in filters to help combat dust buildup. It's helped immensely, but I still get in there about every 6 months and hose it out with compressed air.
Tweakin
2,532
I'm totally under water and I blow out the rads every 3 months, if not more.
BonzaiDuck
16,890
2,208
You had touted your enthusiastic conversion to H2O "religion," and I will eventually follow in your footsteps as a neophyte or acolyte. But between complaints from people about noisy AiO fans, and your observation here, dust is a PITA whether it clogs heatpipe-fins or a radiator.
I'm gonna buy one of those electric "Metro-[something]" airblowers soon, even for their $80-something price-tag. Filters: have to be cleaned periodically. Fins: have to be cleaned periodically. Radiators: have to be cleaned periodically.
And -- a decent paintbrush for cleaning heatsink fins is going to cost maybe a dollar or two.
But it's so, so easy to procrastinate the minor disassembly required for cleaning. Then, a year down the pike -- you see your temperatures spike.
Another reason mainstreamers are going mobile. Mainstreamers don't clean the dust from their OEM computers. They just recycle them to buy a new one!
