duron or t-bird?? help please
nbmeist
82
I've been on pricewatch and I can get a Duron 850 for $75 or a T-bird 750 for $75. I primarily use my PC for games so which will be the better choice? Thanks in advance
Nerd
Banned
Mar 6, 2001
1,365
Take the Duron. It'll more than likely overclock to a GHZ with the proper cooling.
joinT
11,172
unless you're doing some graphics or other high-resource consuming app. (Video / Audio editting, etc) Grab the duron :D-~
nbmeist
82
thanks guys I guess i'll go with the duron then, by the way what is a good site for cooling units?
BadBrad
195
Realistically speaking, they will both perform the same. The larger cache of the T-bird will compensate for the higher speed of the Duron. But if you are going to OC then go with the Duron. They have a little higher OC rate as they produce less heat due to smaller transistor count.
Good site for cooling solutions is kdcomputers.com
