Hello! My Duron 750 is running at around 50C full load and about 35C idle .. Are these temps OK for this CPU? I'm running this cooler : http://www.spire.nl/products/5c12b3.htm , Does any1 use the same cooling unit? Is it OK for a 750 Mhz CPU and maybe overclocking it? Besides I have an ATX case with a 300W ACME power supply (it has only 1 standart cooling unit in the back) and i run it closed. My mobo is chaintech 7AJA2 and i can see from the BIOS "Health Monitor" that my CPU core is running at 1.66V. I suppose that those 0.06V are given to avoid stability problems? Or should I put my CPU to 1.6V as it should work by default.Is it possible? Thanks for replies.y0mAn.
