Duron 600 On MSI K7T pro ???? Help !!!!!
Bucky69
77
Duron 600 on MSI K7T pro.........I followed instructions on unlocking the duron and used a conductive pen..but I still only have fsb & voltage in bios.. there is still no multiplier setting in my bios.Does my bios have the multiplier setting ???? Im using bios version 1.6 the only the highest i can get it is 110 fsb @ 660 mhz..My question is will my bios show a multiplier setting if the chip is locked... or not ????
Nighthawk69
1,113
That motherboard won't adjust the multiplier. You'll have to get a different motherboard to adjust the multiplier.
compuwiz1
Admin Emeritus Elite Member
930
Yes, all are correct. You need the Pro 2 for adjusting the multiplier.
