Durability sleeve bearing case fans? &need for HDD fan?
Bluejay8
Debating whether to buy case fans selling for $5 on special for $1 at www.nexfan.com (sleevebearing) or if it is best to pay a dollar or two more for ball beaaring fans? Will the sleeve bearing types be that much less durable to make them a poor choice?
Are HDD fans a smart option if only using HDD 7200 rpm units. Would the potential extra cooling help extend life of HDD?
Thanks for any comments
Go ball bearing. Sleeve can crap out in 3 months, and the aggravation of changing them eats up the difference in cost.
As for HDD cooling, it is not a bad idea. I keep my HDDs in upper bay external mobile racks and can swap them out in trays. Those racks have their own cooling fans. I use all IBM GXP drives and have NEVER had any problems with them. I believe it is because mine run cooler.
I highly recommend the 80mm Panaflo's w/ hydro-wave bearing (ultra quiet) from bgmicro.com @ 2.75ea if you buy (10).
Panaflo's are sleeve bearing, but because they are hydrowave, and some other crap, they last just as long as a ball bearing fan FYI - you can get some cheap quiet ball bearing fans at electronicsgoldmineelectronics goldmine -- the 1.39 NMB fans are super quiet, but you'll need to rewire them to a 3-4 pin connector or similar (svcompucycle.com has good prices on them)
If you want a standard fan with a regular 3 pin end, check out the deltas for 1.99. They're louder, but not significantly, definately not silent though
I have both of these fans, so if you have any questions PM me
Hope this helps, good luck!
It really depends on the fan. I've seen some cheap sleeve bearing fans run for years without a problem (in fact both my systems have 2 sleeve bearing fans that have yet to fail). I have also seen some ball bearing fans that died in no time.
For things like a PS, CPU, or chipset fan, I would get a ball bearing fan. For case fans, either is fine.
