- Mar 27, 2009
- 12,968
- 221
- 106
http://vocuspr.vocus.com/VocusPR30/...ssetID_EQ=113710&XSL=PressRelease&Cache=False
What kind of impact could this have for computer displays?
it is very tricky still for long lasting large sheets.
Response time for OLED are the absolute best, it would be able to show over 120 fps...
But the best part of the OLED promise is how it's flexible.. Imagine outfitting a "gaming room" where the walls, floor and roof are entirely made of 3d oled
Sony says it will continue to improve the performance and reliability of its flexible organic displays as it expects the technology to yield thin, light-weight, durable and mobile devices with previously unachievable form factors.
How about resolution/pixel size?
I noticed triple layer OLED is capable of 3 times the resolution of single layer OLED due to the blue, green and red being at different levels
it doesn't really work that way... if you have a 1920x1200 resolution blue layer, green layer, and red layer:
1. they need to match up for good quality.
2. they cannot be intentionally mismatched for a higher "effective" resolution
3. the total effective resolution is 1920x1200
I think he meant that in a LCD x1200 display, the RGD diodes are beside each others, so let say each is 1mm arranged in a line, you get 3mm for the pixel. Imagine the same size for an organic diode, but stacking them, you get the full pixel at 1mm size instead of three, effectively allowing 3 times more pixels on the same surface, thus tripling the maximum resolution. This, of course, assume that organic and standard diode are the same size, something I have no clue about.
you can make them different sizes... you could also make them "side by side" or one on top of another.
In the google nexus 1 for example the OLED cells are side by side and are non uniform in size (each cell is 2/3 green, and 1/3 either red or blue, alternating red and blue cells)
So its "effective resolution" is actually a lot less then what they advertise.
