Duplicating a Cable line signal??
DaMenace
Ok, I'm building a computer for a friend and buying a hub for him. He just told me that there is a new $200 router or something like that, that you can buy that should split the signal of Road Runner Cable without weakening it. Supposly, with a normal router it splits the signal for you, so that you can use 2 comps at once. Which of course, would lessen your max connectivity speed right?? How would you built a router that Doesn't lessen your max connectivity speed. Sorry, never really looked into how Routers and stuff worked. Can anyone give me some help on what my friend is talking about?
A router doesn't just split the signal, it gives each comp its own IP address. Yes, the bandwidth will be split between both when you're using them at the same time, there's no way to get each of them to get all the bandwidth. (unless you have 2 modems and 2 IPs)
---cable--->---cable modem--->----router---->---hub/switch===>>pc1 and pc2
the only splits before the modem on the cable line would be to split one for RR, and 1 for watchin cable tv
sugardaddy explains it very well, I don't believe your friend know what he/she is speaking about.
