Dunno if i screwed up cleaning up that thermal compound . .
Oct 28, 2005
50
I'm currently trying to salvage a P4 Northwood. Under some advisement of some friends I bought the clean kit from Arctic Silver. (Artic Clean). It works pretty good. Yeah I know going with alchohol would have been cheaper but for 5 bucks for the kit I can't complain.
Anyway, there is a crevice (1 mm hole) in the corner of the Northwood. Its pretty much a tell tale that its an intel processor. Well with the previous heatsink (stock intel thermal pad) this hole is now jam packed with thermal pad material.
1. First off, do i need to clean this out?
2. If so how do I do it without damaging the chip?
3. Is it a problem if I get some cleaner on the green (base) portion with which the cpu rests on? Its all cleaned up and dry now.
If someone can answer these 3 questions I'd greatly appreciate it. This is my first major upgrade (replacing a stock mobo). Thanks in advance.
StrangerGuy
8,443
124
Information about the IHS hole.
I believe there is no harm done if the hole is filled with thermal compound, so don't worry about it.
TSS
227
yeah doesnt seem a big problem if thats filled with thermal compound... i mean when your HSF's on the IHS itll smear compound in there anyway (just a little but still) else still block it off completely. so no worries really...
