jukeboxjoe
Installing and running the Command Line Tools
1. Run freecommandlinetools.exe; choose the
drive and folder into which you want to
install the free C++Builder 5 command line
tool development system.
2. From the bin directory of your installation:
a. Add "c:\Borland\Bcc55"
to the existing path
b. Create a bcc32.cfg file which will set
the compiler options for the Include
and Lib paths (-I and -L switches to
compiler) by adding these lines:
-I"c:\Borland\Bcc55\include"
-L"c:\Borland\Bcc55\lib"
c. Create an ilink32.cfg file which will set
the linker option for the Lib path by
adding this line:
How and where do I perform steps 2a,b,c? They assume I'm not a total idiot, but I am!
Just started with C++ and need compiler to finish lessons. Lost my CD with Vis C 6.0. Just started working with software again after many year layoff and now on disability needing re-training. I can build a PC, I just can't remember how to do this! Any help appreciated. Help un-dummify the World!
adding this line:
