Dumb Question!! What can a switch do for my home network in terms of speed??
kehi
3,357
Hey guys I am new to the whole idea of switches because I have been using just a regular 8 port hub and sharing the internet connection across it. Just lmk if you think a switch is worth it when it comes to home networking and what can it do. Thanks to all and take care
Hoober
4,431
69
I'd say just for basic home use that a hub would work just fine. If you're doing a lot of gaming/LAN parties on the hub, however, I would recommend a switch. The switch will allow you to work in Full duplex mode -sending and receiving- at the same time, as opposed to the one way communication that hubs limit you to.
SaigonK
7,482
www.robertrivas.com
A switch is always worth it, especially nowadays since they are sooo cheap!
if you are not doing alot of file swapping and other forms of data moveing on your LAN then a hub would be fine to just connect you for rare file transfers and sharing to the net.
For more bandwith go with a switch.
The math is as follows:
If you have an 8 port 10/100bt switch the max rate is 100mbit/number of ports in use.
So if your hub has 8 pc's connected and they are all on moving data, your 100mbit is dvided up between all available ports.
With a switch each port has 100mbit dedicated to it, no sharing.
As you can see this makes things alot better! :D
