- Dec 10, 2000
- 431
- 0
- 0
I'm planning on building a new system soon, and I'm trying to figure out what RAM to use. Anandtech's high-end buyers guide recommends this:
http://www.newegg.com/app/ViewProductDesc.asp?description=20-146-294&depa=1
Mushkin Level One Dual Pack, which is PC3500, 2-3-3, and the guide shows it as being "CL-2".
My (dumb) question is, can you run that RAM at PC3200, CL-2 (2-2-2-6 or whatever that would be) since the lower clock speed should allow it to hit lower latencies?
Would the SPD info on the chips tell a motherboard to default to PC3200 CL-2, or would it default to the higher latencies that it's rated for at PC3500?
As long as I'm asking, should I avoid Mushkin? I usually buy Crucial, but they only have CL-3, and Corsair's more expensive (not even sure if they've got CL-2 RAM or not). For that matter, should I just save $50 and go with CL-3 or CL-2.5 RAM?
Okay, I didn't intend to start asking all these questions, but...
i865 or i875? Worth a $40 difference? So many choices...
Thanks!
Thanks!
