Dumb Question : How Do I Set The CPU Speed On My EPOX 8K3A Motherboard?
Kenji4861
Banned
Jan 28, 2001
2,821
I have a XP2000 with a Epox 8K3A, I am having problems setting it to XP2000. It sees it as a 1200mhz. Any information will help, sorry for being a newbie. What do I do in the CMOS?
CubicZirconia
5,193
Enter the bios and go into the frequency/voltage control section. Then change the cpu speed (fsb) to 133 instead of 100. It should post at 2000+ then.
Zim Hosein
Super Moderator | Elite Member
65,304
403
Kenji4861, there is a jumper on the 8K3A that needs to be set to make the FSB go from 100Mhz to 133MHz, hope this helps :)
