dumb question how do I check my monitor model?
Cappuccino
4,018
726
Hi how do I check my model or the actual name for my PC monitor? All the stickers are gone and I dont see any serial numbers anywhere? really appreciate the help
Essence_of_War
2,650
4
If you're on Windows, under Control Panel, and then, under Appearance and under Personalization, the Adjust screen resolution option should give some info about your monitor.
vailr
54
Was this monitor purchased used, or something?
The first thing to look at would be in Windows Device Manager.
If that only says "Generic Monitor", then check Windows Update and see if specific drivers are available that way.
If not, then use a flashlight and carefully inspect the monitor's exterior for any kind of identifying marks.
Some LCD monitors built-in on-screen adjustment menu may include the model number within the menu.
