I figure this is valid for this forum since things generally ground to your case...anyway.
In this thread, UnixFreak said:
<< Make sure the motherboard has at the least, 3 points at which it grounds at the chassis. >>
I've never actually built a box from the ground up before, but will be doing so over the next few weeks. From what I understood before, to mount a motherboard, all you do is put in the correct standoffs, place the motherboard correctly over the standoffs, and screw it in. From what UnixFreak is saying, it sounds like I'll also need to ground my motherboard to my chassis. I'll be using an EPoX 8K7A+ and a Chenbro Junior...so how would I go about grounding my motherboard? I always thought that the ground for the motherboard was supplied on the ground wires coming from the power supply, and that grounding your motherboard to your chassis was a bad thing that would cause all kinds of weird problems. I dunno, any help from anyone would be good...thanks.
J3
J3
