Duct work material suggestions for PC...
Electric Amish
23,578
Over the weekend I installed a 120mm fan on my case sidepanel and I want to put a duct from that directly to my 60mm Alpha HS (sans fan). I'm currently using some chopped-up manilla file folders and tape. I'm in search of a more permanent/better looking solution. Anyone here have any suggestions??
tia
amish
Siva
5,472
cardboard, hot glue, and sealent.
a duct is a duct, maybe its not pretty but it does the job
skywhr
3,866
you can get 3" or 4" diameter flexible duct work @ your home improvement store
iamwiz82
30,772
13
My idea calls for 7 feet of barbed wire, a small tazer and a rubber chicken...
samgau
2,403
You could use the aluminium ducts sold for clothes dryers.... its pretty flexible (made of basically layered aliminium foil)... and you can cut it to fit... its normally cylindrical... just be careful of not shortcircuiting everything.... or maybe you should go with something plastic.. :)
GasX
29,033
<< toilet paper rolls >>
better yet, really big rolls for the industrial sized TP rolls. They are stiif and have at least a 120mm diameter...
skywhr
3,866
Get a circle 5&quot; to 4&quot; fitting run a 4&quot; flexible duct to a 4&quot; circle to 2.5&quot; square adapter/reducer
Windogg
Amish, like I said above, use a 2 liter soda bottle. Cut off the two ends and then a &quot;V&quot; shaped notch in to funnel down the size.
StrangeRanger
Amish, there is one thing you should check/watch for when you are reducing the duct. If you reduce the diameter of the duct over too short of a distance you will actually end up with back pressure from the air rolling back off the funnel which will obviously not be the result you are looking for. Just an FYI for you.
But I like the start with a 2 ltr soda bottle idea. Just cut the bottom off and cut the top end off at the diameter you need. Oooh! Bonus to the soda bottle idea, you could even tape/glue some colored streamers inside it and have yourself some built in fan-blow in the wind-thingies :)
j
Electric Amish
23,578
What's the best way to &quot;glue&quot; the edges of the bottle back together after they've been v-notched?
amish
Windogg
Goto Home Depot or you local hardware store and get some epoxy. That sucker ain't going anywhere after that. Of course if you screw up, it means chugging 2 liters of soda to fix your mistake. :)
Demon-Xanth
20,551
Just leave it open. That's what I'm doing with my 120mm panaflow and coolermaster HSF (the 120mm spins the 60mm 900RPM faster)
Electric Amish
23,578
If your 120mm is spinning your 60mm, it's just going to cause airflow disruptions.
I added this 120mm fan on the side panel over my CPU as well as this 120mm fan as a front intake fan. I removed the 60mm fan from my Alpha PAL6035 and ducted to that first 120mm fan. This dropped my CPU temp to 50°C on a Duron 800@1035 1.89v. :D
amish
Balt
12,673
482
I would avoid using anything metallic as one person suggested, that could only lead to great unhappiness.
Demon-Xanth
20,551
<< If your 120mm is spinning your 60mm, it's just going to cause airflow disruptions. >>
I have a switch to turn off my 120mm fans and 60mm case fans for overnight. I also don't want my CPU to fry when I open the case when it's running. I CAN however run my PC w/ case fans on and CPU fan unplugged. (the temp is 3F higher than CPU fan on and case fan off)
I love high speed panaflow fans!
virtuamike
7,845
13
LOL!!! Industrial sized TP for industrial sized dumps :)
