- Jul 26, 2001
- 12,375
- 10
- 81
Okay.. my intake for my car came today-- and just as i was finishing up with the installation, i realzed that one of the rubber couplers is missing. pic I'm supposed to have 2 of those rubber tube things so i can fit the pipe in between the blue pipes. make sense? Its a 3 inch inner diameter rubber tube.
I called AEM, and they're going to ship me a replacement.. howeever, until then-- i need to be able to drive. NO stores at all in the area carry rubber tubing with that large of a diameter. So, my thought is that for temporary purpoases, until the replacement comes.. i could just ductape to hold things together. Will this work?
what should i do?
i'll get more pics up in a while.
update:
okay, so here is my temporary solution, i took a piece of rubber tubing from the stock intake... it was only about 3/4 of an inch long though. so i made a ducttape tube first, and put that around the pipes, the i took the short rubber hose from the other intake, put taht over these two right at the joint, and tightened it up as much as i could. Then i took electrical tape, and sealed up everything really good and made sure nothing is going to shift around or move.
this will at least get me going so that i can search around town for another tube, or pick up a piece of pvc liek MichaelD suggested. The replacement tube should get here friday I hope, becuase i go back to school on sunday.
oh well.
i'll get pics and everything up as soon as possible. also made a recording of engine sound before and after the intake.
now for a test drive.
what should i do?
update:
oh well.
