neutralizer
I just recently added an 92mm fan to my Enlight 7237 which only takes 80mm fans. Instead I used duct tape and taped my 92mm to the side of my case and tailed it so it would fit on my mobo. Now I was wondering if anyone had done this and if you do an OK job, about how long will the duct tape hold before the fan falls off. BTW, the fan is set to suck air out of the fan and is rated at 38 cfm. I'm worried about this because if the fan fell off, it wouldn't get detached from the power and continue running while it smashes into my GF3...
