- Dec 20, 2004
- 2
- 0
- 0
Greetings Anandtech Folks!
I am hoping you folks can help me figure out what is preventing these Asus Dual Xeon mainboards from POSTing. I've built dozens of systems, but never one based on Dual Xeon / Intel E7320 604-pin processors.
Could someone provide a link to a step-by-step guide specific to 604 Xeon systems?
We've had at least 2 of our techs here attempt to troubleshoot the first mainboard, we ordered a Replacement board (They are Asus NCLV-D(A) boards) and it is showing the same problems.
First question first: Is there some sort of failsafe mechanism that prevents the board from POSTing if the massive heat sink retention mechanisms are not assembled? We are testing the board outside of the case to avoid remounting. the HSF is making good, solid contact with the CPU, so I have trouble believing it is an instant thermal cutoff situation.
Symptoms:
Power supply connected to mainboard, two headers. 3-pin fan header connected to CPU socket 1, relevent jumper set for 3-pin operation. Standby power light is lit. Activate power switch, connected fans start spinning. There is No video signal output from the properly-enabled onboard video. There are no POST beeps from the speaker (tested 2 known good speakers). I attempted to use a PCI POST diagnostic card, and it doesn't display ANYTHING on the readouts. VERY odd.
Just wondering if there's a step we're missing, that's different from Workstation system builds. Any recommendations are greatly appreciated.
Symptoms:
