Dual Wireless Connection??
frank84
1,835
www.enomooshiki.com
for my laptop, i have internal wireless card AND external pc card that i carry around.
right now, both of them are connected to a same access point.
which wireless device will windows use to communicate?
if my 2 wireless devices are connected to 2 seperate access point/wireless router, what would happen?
-frank
n0cmonkey
42,936
You'd potentially be on two different networks at the same time...
JackMDS
29,563
432
In general it is a useless configuration.
You can not use the Internet with both in the same time.
It is hard to guess which connection Windows would pick; it depends on few parameters, if you want to force it to prefer one connection this might help, http://www.ezlan.net/metrics.html
If you have other specific goal in mind state it.
:sun:
frank84
1,835
www.enomooshiki.com
Originally posted by: azev
whichever connection has the highest metric will win.
the thing is..
that is not what happend.
windows actualy choose 'weaker signal' to be used
found out by watching taskbar icon blinking..
i know it is useless since windows will only choose one,
just curious about things..
-frank
Fardringle
9,200
765
the thing is..
-frank
It's not "whichever connection has the strongest signal", it's whichever connection has the highest metric set within the network connection parameters in Windows. If you want to understand the difference, read the link that JackMDS posted. :)
