Bill Kunert
I recently went from a Celeron 1300 to an AMD XP2600+M. My 300 watt supply was fine for the Celeron but appears weak for the AMD. All voltages are OK except 12 volts which runs from 11.2 to 11.4. Is it possible to use an older AT supply to supply 12 volts to the P4 connector on the board to supplement the 300 watt supply? I hate investing in a new 450 watt supply but will if this won't work. I know the grounds on both supplies have to be commoned but are there any other problems?
Thanks
Bill
Thanks
Bill
