First off all, im looking into picking up parts off ebay, the for sale/trade forum and either refurb or lowcost new parts off websites.
I have a few questions..... I want somewere between 700mhz - 1.26ghz dual system. SDRAM or DDR. I already have 128MB of PC100 and drives. I want to build the system for fun, and as a LAN party server for weekends. Plus use it as a print server and MP3 server during the week. I know i could continue using my PII server to do this, but I want to do some experimentation. I missed out on the P3 generation, and i can think of nothing more fun than tinkering with an older dual cpu rig.
1.) First off what sort of motherboard should i look at? Slot 1 or Socket 370?
2.) If i go slot 1, can a 'socket T' or slocket give me the option to run a tualuatin down the road.
3.) which CPU's can run in dual mode? I know P3 Tualatin-S can, what about the older generation coppermines and before? Can any celerons run dual and if so what sort of mods do i need to do this?
4.) is it worth going with the 'newer' Via DDR chipset? I can pull 512MB DDRfrom my system and treat myself to an upgrade on my main rig. Does the Via chipset allow more than 512MB of ram?
What i was thinking was getting a 'really good' Slot 1 mobo. Getting some socket370 adapters and putting in some cheap dual capable P3s or celerons. I just want to know if that will work.
Ok im making the post really long... sorry about that. I just need something to mess around with for as cheap as possible. What do you all recommend?
