Dual-Output 6800 Ultra
Brainiac2000
157
I've got my 6800 ultra and i've noticed the performance hit running two displays while gaming. Is there any way to optimize this or am i stuck with always having to disable my 2nd screen before gaming?
Thanks.
btw just got my 2 2001fp's and they rock!
edit: i'm using the dual dvi outputs
stardust
1,282
Download latest nvidia drivers (61.77+) and in the nview display settings tab, there is a pull down menu where you could select monitor configurations and such.
Rage187
14,276
4
each display has it owns display properties in the control panel.
Make sure they are running the same resolution and color depth.
