Dual Monitors Trouble. Please Help it won't let me maximize on the Secondary Screen
Krueger81
4,196
Help
I have been trying to get this dual monitor system to work for the last hout or so. The problem I am running into is this:
Whenever I try to maximize something it maximises in the Primary Display . I want it to maxmize in the Sec Display Though. Is there any setting that I have overlooked. I have installed Hydravision and extended the Secondary Display to the Rigth.
Thnaks bunch in advance.
Phil
powerMarkymark
2,164
I've been using triple monitor display setup for two years now and most multimedia apps will maximize to primary monitor.
What are the specs of your setup? Are you running two vid cards or a single vid card with dual head? (I suspect the latter)
Are all apps maximizing to primary? Word, Excel and the like should maximize to secondary just fine.
Are you using two monitors or one monitor and a TV as secondary?
I have a little program called UltraMon tha gives you more control on expanding apps, Might work for you too. You can find it on the Net.
