I'm currently running dual Samsung 900nf 19" CRTs on a Radeon 9000. I do a lot of Photoshop work so I need the highest resolution possible. Right now I'm running both monitors at 1800 x 1440 x 32bit x 70 Hz. The display quality is phenomenal, but the 2D performance is awful, with really laggy drawing and slow window opening/closing. The behaviour is similar to when your system is really low on RAM, but I have 1.5 GB so that's not the problem.
My question is: Is the crappy 2D performance caused by a lack of bandwidth in the 2D engine of the Radeon 9K or is this something that can be fixed with drivers? I figure I'm pulling 2 x 1800 x 1440 x 4 bytes/pixel x 70 Hz = about 1.38 GB/s out of the 2D core. Has someone experienced similar problems? How do high-end media designers run multi-monitor setups at high res with good 2D performance?
Thanks
Thanks
