Dual monitors on a motherboard with VGA/DVI?
RebateMonger
11,586
The spec sheet for that motherboard says, "Multi-VGA output support HDMI, DVD-D, and RGB ports".
The English manual, on page 2-22, says, "This motherboard comes with multiple VGA-output that features desktop extension on two monitors. You can connect two monitors to any of the onboard VGA, DVD-I, and HDMI ports.
Rifter
751
I would say yes. Sometimes you run into problems with trying to use 2 digital connections from onboard graphics and are only able to use DVI OR HDMI with VGA but since that is what you are trying to do you will be fine.
