I just bought my first lcd (Dell 18" Ultrasharp) to replace my Viewsonic 19" crt. I am accustomed to 1600x1200 on max settings so I was sceptical at first if it could replace my crt but I was -very- impressed with this lcd. Now, I have the following conundrum, I assumed that the monitor could support two monitors but I have learned otherwise. After doing some research, I have two options (that I am aware of).
1. Try to use a splitter which allows for dual support. This is -not- a guaranteed method but it is the cheapest for a $50 cable (if it works)
2. Buy a 2nd vcard that is radeon based. A lot more expensive option. Which is a decent card with ok 3d abilities? Can I use a GForce card or will there be driver conflicts?
Thanks for your input and advice. I really like this lcd as well as my old one, would love to use both at the same time.
