Dual Monitor Users in Win2K, need your help
joeryu
1,678
hi, i want to run dual monitors in win2k, with a primary (ATi AIW Radeon) and a secondary card. if you guys run the type of setting i want to run, what video card is your secondary card?? i want to know what works so i know what to buy. i have a pci s3 trio64 but it wont work. what vid cards do you / have you used and what were your experiences?? thanks for your help...
SatorE
im using win2k radeon 64mg and a mighty savage4. No probs at all. I have just installed the latest ati drivers and they have made the multi monitor support a wee bit qwerky ie it places all my icons etc on my secondary monitor. Previously to this set up I had a g 400 max which was a far more elegant multi monitor solution.
Cheers Craig
Sundog
12,342
W2K with the primary monitor being a AIW Radeon AGP, and the secondary an old 4MB Matrox PCI. Worked fine.
bassoprofundo
1,948
7
www.heatware.com
My machine at work has an ATI Rage Pro Turbo AGP and an piece of crap PCI 2mb ATI Mach64 in it, and they play well together. I've also got a machine with an AIW-128 16mb AGP and a Matrox Millenium 4mb PCI working together. I would say you should pick up one of the old Millenium cards. You can find them at various places on the web used for about $30-40, and you can't beat Matrox's image quality. Stay away from any earlier S3 card. They don't support dual monitors at all.
joeryu
1,678
any experiences with the Matrox g200?? can this card be run as secondary under win2k?? lmk, thanks!
