Dual Monitor Sleep Problems?
Vilica
Just upgraded to dual 2001fps from 2 17" LCDs, same video card, no driver updates. If I leave my computer for a bit, and turn both monitors off, upon my return the left hand monitor turns on and displays, but the right hand stays off. Both are connected via DVI, and the only fix I've found is to disable the right hand monitor, hit apply, then re-enable it, and then drag everything back over to its rightful place. Anybody else had this problem or something to that effect? Google was unhelpful on a rudimentary search.
