biohazard420420
There is another thread with a similar topic but I don't want to "thread jack" since my questions are different than the one in the existing topic.
I want to run dual monitors on my new computer when I get it built, I do some gaming sometimes frequently sometimes not, as well as normal pc stuff email web surfing etc. I am looking to buy a fairly high end ATI card like an x1900xt or something close to that depends on whats in my price range when I acutally build my new rig. From what I understand since it has dual dvi output I can run monitors from the card. I will be running either 2 17" or 2 19" crt monitors on my new build. Please no "which is better" concerning either ati vs nvidia or crt vs lcd. I had used a dual monitor set up a few years ago, well about 4 to 6 years ago at a camp one summer, they had it set up so you could drag and drop windows, etc. from one monitor to the the other which is what I am going for. Here are the 2 questions I have:
First I have seen UltraMon mentioned a few places concerning multi mon set ups, will that let me just drag and drop windows from one monitor to the other like it is one giant desktop or do I even need that program.
And second, when I run games can I make it run on only one monitor? I have seen several posts about resolution differences between what the desktop is set and and what the game is set to causing the desktop to get shifted around. That is not a problem since I will most likely turn the second monitor off when I game as long as I don't have to go reset the desktop resolution when I stop gaming.
Thank you for your time and imput.
