Spike
Ok, I have a 21" Nokia 445Xpro and a 17" sylania F77. I have the nokia hooked to my Radeon and the sylvania to my old S3 trio PCI card. For some reason, I cannot get them to both work when I am using the radeon as my primary display driver. I am running a ECS K7S5A with a athlonXP 1800+ (not that it matter as this is a monitor issue) and I can change my bios settings so that the PCI card is my primary display driver, then both monitors load up just fine and I am in dual monitor heaven. there is one snag, however. When running the PCI as my main driver, I cannot adjust the refresh rate on my radeon, it is stuck at 60hz, which is not very pleasing to the eyes. However, when I run the radeon as my main card, the other monitor does not work but I can put my res up to 1600x1200 and have the refresh at 85hz. Does anyone know how to work around this? thanks
