Question Dual monitor placement- left or right of main monitor?
AMD64Blondie
1,744
152
I'm going back to dual LCD monitors after a while of running only 1 LCD.
(Main LCD is a 32-inch Samsung 2560x1440 S32D850, the second monitor is a 22-inch Dell SE2219H 1080p .)
Trying to decide if I should put my 22-inch LCD on the left of my 32-inch main LCD. between my 32-inch LCD and my full-tower case.
(Or on the right of my main monitor, between the 32-inch LCD and the wall).
Thankfully, I bought DisplayFusion, which IMO makes setting up multiple monitors so much easier than from within Windows.)
Any opinions on left or right placement?
Hans Gruber
2,517
1,358
It depends if you are left or right eye dominant. You want your big monitor in the middle and decide if you want the 22" to the left or right of the 32".
AMD64Blondie
1,744
152
Left eye dominant.
(I'm left-handed.)
Ended up putting the 22-inch Dell LCD on the right of my main Samsung 32-inch LCD.
mindless1
8,755
1,760
Between the 32" and the wall. You don't want it impeding access to swivel your full tower case around to clean the spiders out. or dust. or something.
