Dual monitor help..
VigilanteCS
Hi,
I ran across an extra monitor and I'm using it as a second monitor hooked up to my Dell Inspiron 9300 (Geforce 6800 Go 256 mb). My question is this...with dual view can I get it so the extra desktop is off to the left side of the primary monitor rather than off to the right? The only place I have space for the extra monitor is on the left, and it's annoying moving the mouse to the right to get to a monitor on the left.
Thanks!
Originally posted by: VigilanteCS
Hi,
Thanks!
you can drag the monitors where you want them in the display tab.
Hi,
Thanks!
Solved my problem, thanks a lot =).
