Dual Monitor causing a BSOD?
Adrenaline
5,320
8
This may sound dumb, but can this happen? I connected a second monitor the other day and I experienced a blue screen:
ntoskrnl.exe
I tested my RAM with memtest and the cpu and got no problems.
Four days later I got another blue screen:
dxgmms1.sys
ntoskrnl.exe
I disconnected the second monitor and updated my video card driver just now. Any other suggestions? I built this computer a few months ago and aside from startup issues, it has been solid until the second monitor was hooked up.
Ketchup
14,559
248
Are you seeing the IRQ_NOT_LESS_OR_EQUAL or is it something different?
Not knowing the rest of the blue screen message makes it difficult to know a specific cause.
Is anything on your screen when you enable the second screen? Like Chrome or Firefox (since they use your video card).
On the surface, it is most likely a video card driver issue. What card? Is it is an Nvidia card and you use Chrome, there is a driver specifically targeting Chrome issues.
Adrenaline
5,320
8
I do not recall seeing the IRQ_NOT_LESS_OR_EQUAL message, either time.
I shut down the computer and reseated everything and then updated the video card driver. I did have Chrome open on the second monitor with me switching back and forth while playing a game on Steam.
Zotac GTX 970 is the video card.
Adrenaline
5,320
8
I got a BSOD for my sound card driver. I am trying to delete the darn folder off my computer which is suggested but it will not let me do it. I even pulled the card out and disabled everything I could find.
I may just reformat and start new.
Ketchup
14,559
248
There you go. Download the latest driver, discussed here:
http://forums.anandtech.com/showthread.php?t=2437331
Adrenaline
5,320
8
Thanks for that. I will get it later when I am home.
I did get a cmudamp.sys blue screen later which I just reformatted. Since, there isn't much on the computer it is quick. I will update the drivers later.
Thanks for taking the time to help me. I want to use two monitors so this should fix any issues.
