Davidh373
Hi, I have a friend that recently bought a secong XFX Radeon 5770 to run in Crossfire. One has a single connector and came with a single ribbon cable, while the new one has dual heads, and came with a double ribbon cable. I'm not sure if it makes a difference or not. Why do you think they would make the cards different? Will it make a significant performance difference if he can't use the double ribbon?
