Thinking about getting a Matrox G400, maybe a G800 whenever that thing comes out... I have a Hauppauge Wintheater TV card... will the two go together? Anyone know of any known problems?
I have a Dual G400 with a Pinnacly System PCTV. TV only works on Monitor 1 not the second one. I have a WinTV card that has the output plugs that I think you can output to either monitor. Should be no problem.
