- Apr 1, 2012
- 50
- 5
- 71
Hello everyone.
I was thinking of buying the parts below and already contacted shops trying to get the motherboard and CPUs, in the Netherlands, which makes that kind of difficult. I tried to keep the cost around €2000, for which you can usually get the same here as for $2000 in the USA. Here's the list:
I will be using this system for fractal rendering in fractal extreme and apophysis, fractal software for windows. Basically:
The CPU that got my interest immediately when I began looking for parts was the AMD opteron 6272, the least expensive of the three 16-core versions of the interlagos CPUs, which have 16 integer cores and 8 float cores. I wish they had 16 float cores as well, but can't have everything for $540 on newegg.com, a very good price. No other high-end server CPU is that cheap and it does perform well in benchmarks by anandtech. Intel appears to be insanely expensive, so I didn't spend much time on that. I don't think the faster opteron 6274 or 6276 are worth the extra money for the small performance gain.
I'm currently rendering an image that uses 960-bit calculations, to give you an idea of the precision required for deep fractal renders. AVX-instructions could speed-up this kind of work in the future, which the interlagos CPUs support, so they're future-proof.
There are 2 people I know who have respectively an intel 2600k and an amd fx-8150 (same bulldozer architecture as interlagos) who wanted to help me, and the programmer of fractal extreme did a benchmark with his intel 3930k, all in fractal extreme. The benchmarks in this particular program:
Then with the CPU in mind comes the choice of the motherboard. It needs to have 2 g34 sockets. Asus kgpe-d16 is cheapest for $430 on newegg.com and everyone uses it instead of the alternatives tyan or supermicro, so I guess it must be good.
What do you all think of the CPU-motherboard combination for this purpose?
I am aware that the kgpe-d16 motherboard's bios doesn't always support the AMD opteron 6200 series processors. Information on this:
http://dlcdnet.asus.com/pub/ASUS/mb...enual_QVL/KGPE-D16_Interlagos_Support_new.pdf
I am aware that the speed per core is low, but that's no problem because there's always enough to render.
If you have any ideas, negative or positive, please post.
If you have a 64-bit CPU and OS you can help by running this fractal extreme benchmark program for only a few seconds and post the results:
ftp://ftp.cygnus-software.com/pub/InfprecPerf.exe
I've left out the results of the CPUs already tested in this program but if needed I'll post them later.
Sorry for writing so much
Also if you want to know more about what I do, visit my deviantart and youtube accounts:
http://www.youtube.com/user/Dinkydau00
http://dinkydauset.deviantart.com/
Code:
motherboard: Asus KGPE-D16, 2× g34 socket
CPU: 2× AMD Opteron 6272, 16-core
RAM: 4× Kingston DDR3, 1333 MHz, 4GB kits (2×2048 MB)
GPU: (my current) nVidia 8800 GTS, 512 MB
storage: (my current) 750 GB HDD and 2 TB HDD
sound card: some cheap sound card should be enough
cooler: noctua nh-u9DO a3, amd opteron, socket g34
power supply: Corsair 750 watt ax750 gold
case: Cooler master HAF932
- apophysis: a lot of floating-point operations
- fractal extreme: a lot of integer operations
- intel i7 2600k as reference
- amd fx-8150 bulldozer is 35% faster
- intel 3930k is another 10% faster
