InflatableMouse
Hi all,
This morning out of the blue (pun intended) my pc crashed with a stop error 0x1a and wouldn't boot up normally after that (bluescreened during boot). Nothing changed, not even a USB device.
A couple of weeks ago I did replace some hardware. Harddisk was replaced with an Intel SSD 80GB and I expanded the memory from 2x2GB to 4x2GB and I got an OEM copy of Win7pro 64bit with that as well.
Hardware was replaced 1 piece at a time and a clean install of Windows 7 was done after everything checked out.
The memory was fully tested overnight with memtest86. No faults found.
I've read 0x1a is generally considered faulty RAM so I booted up my memtest86 3.50 CD, default mode (single CPU). Within seconds, pc reboots.
I load up BIOS defaults, and make sure RAM and CPU settings are set to proper settings (SPD, not OC'd, default voltages). Reran the test and it reboots again.
I take out all my RAM modules, and put 1 in socket 1. During POST I see it's running Single Channel configuration (obviously).
Memtest finishes without any errors. I repeat this for the other modules same story, no errors.
I continue by putting 2 in (from the same kit) and memtest fails within seconds.
I switch them around in different banks, basically all possible configurations. The test always fails within a few seconds (reboot).
Replace the modules with the other 2 and repeat memtest, reboots within seconds.
I continue testing and any combination of DIMMS in any slot fails. Any single DIMM in any slot works flawlessly.
I have reseated everything and made sure all contacts are clean.
MB is a Gigabyte Ep35ds4, c2d 3ghz and 4x2GB Kingston value Kvr800.
I wish I could force the MB in single channel with 2 or 4 DIMMS, but I can't find out how. Even with 1 DIMM in a yellow and another in a black slot puts the MB in dual channel mode.
I am ready to blame the MB having gone haywire, but since I have had a similar issue years ago with an AMD 3200+ I wanted to post this up first. That issue was caused by the CPU not matching the memory speed (166 vs 200Mhz). Clocking down the memory bus to match the CPU clock of 166Mhz fixed the issue.
I don't think this is the same issue again, but maybe it is some setting related issue that I am missing.
I have tried clocking down both the CPU and memory buses and I have also upped the memory voltage by 0.15 to see if it would stabilize.
Any ideas would be appreciated.
TIA!
TIA!
