I have an IBM T60 laptop with Win XP Pro SP2 on it. I use Partion Magic v8 to create a 2nd partition on the HDD.
I'd like to install Win XP Home on the 2nd Partition.
(I want a clean boot up to work exclusively with video applications, as my Win XP Pro - gets bogged down by a lot of apps running on it) - I chose the Home version of XP for the 2nd partition - b/c I happen to have a license for that.
Anyway - Problem is that when I put the Win XP Home CD in it says that it does not see any Hard Drives to install onto????
I've set the partition to NTFS, Fat 32 - no difference. Also set to Primary or logical partition - still nada.
Any ideas?
TIA
Any ideas?
TIA
