indigowindow
i have 98se on partition C and 2000 on partition E. when i restart in ms-dos and type scanreg/fix i'm assuming it's going to the C drive. is there a similar command to fix the registry in 2000? and if so, how would i direct it to the E drive?
my other 98se registry tools are jv power tool and the turquoise box with the red ribbon - regclean. and iolo system mechanic until the trial period ends. are there any problems using these in 2000? should i be asking these questions in the windows 2000 forum?
would there be any bad side effects if i used the me defrag on the 2000 partition while i'm operating in 98se?
