- Aug 17, 2009
- 5,195
- 1
- 71
So, after seeing what the 780 cost, I've decided to get dual 7950s instead.
My rig is in the sig below. My case isn't known for its cooling abilities and I had issues keeping my 6990 cool, but I also prefer a quiet case.
So I don't know if I should get 7950s that have the reference cooler or Something like the Windforce 3x or Vapor-X coolers cause I don't know if I my case will be able to handle all that heat.
I wanted to know what setup would put out more heat. 2x 7950 or a single 6990. And then also noise. I am currently running a reference 5850 and the noise isn't too bad, I wish it was quiter, but It's bearable. How does that compare to a reference 7950?
