- Mar 30, 2003
- 6,858
- 12
- 81
Found here.
Features/Specifications :
[*]External Firewire 1394 Drive Casing[*]Oxford Semiconductor OXFW911-TQ-A / Realtek RTL8801 Chipset[*]Two 3.5-inch Drive Bays[*] Two IDE/ATA Connectors[*]Works with Any 3.5-inch IDE Device (Hard Drive, Zip Drive, Etc...)[*]Two External IEEE 1394 Firewire Ports[*]Power Switch / LEDs on Front[*]Power is autoswitching 90-264 AC A 50/60Hz[*]8 x 8 cm Fan mounted on back.[*]Supports: Windows 98SE, Me, 2000[*]Successfully tested in Windows XP.[*]Also supports Mac OS 8.6 and up, including Mac OS X 10.1.2, w/built-in drivers[*]Includes: Case, Driver CD, Power Cord, Mounting Screws
Manufacturer is Mapower.
Above price does not include shipping. Appears to be between an additional $6.00 to $8.00 via FedEx Ground, which, considering their weight, is reasonable.
These are really well built, sturdy enclosures. Have personally had one running nearly 24/7 for last 18 months or so without fail. Works flawlessly under Xp. The price reduction (these were $56.95 a few weeks) is most likely a preemptive attempt by Computer Geeks to reduce their stock, as they will be offering the 5.25" dual bay version of these enclosures later this month or next.
Update - 6/27
Previously $47.95, Computer Geeks is now currently promoting one of their subscriber exclusives containing the following :[*]The above described dual 3.5" bay firewire enclosure[*]VIA VT6306 3+1 Port PCI FireWire Controller Card. Specifications are found here.[*]Firewire Cable 6-pin to 6-pin Cable - 6-Foot. Specifications found here.
Quoting from the email :
"Add the Firewire Case to your shopping cart and enter the Secret Savings Code in the red "promotional code" field during checkout (Firewire Card and Cable will automatically be added with code) to SAVE Over $20.00 and get this External Firewire solution for just $57.95!"
Code is readily available elsewhere, and thus not included in the above.
Update - 6/27
