DSLReports.com speed test check please
Please goto here (dslreport's megapath server) and see if you're getting what you should be. I'm trying to track it.
Thanks, and please post here with speeds you should be getting and speeds it is.
I should be getting about 3000/240, but am getting 500/240.
I'm at work right now, but the last time I ran their speed test my connection (RR cable) was quite a bit faster than advertised.
dosen't seem to be working for me at the moment. I used to get about 3200/120 which was about right. I just moved and now I'm on wireless which blows.
It's not working for me now. But last time I tried megapath and linkline, I got about 1/5th the speed that I got on linkline.
2004-11-16 15:30:41 EST: 1371 / 235
Your download speed : 1404342 bps, or 1371 kbps.
A 171.4 KB/sec transfer rate.
Your upload speed : 241598 bps, or 235 kbps.
Work, Comcast
150 down
1685 up
last time i checked with another tool, i got WAY different numbers...
i'll redo the test and post it online again
it's weird, but i'm getting higher upload than download speeds....dno why...
i wouldn't know anything about how to configure any firewalls because i'm on a uni connection, but it's pretty weird that it's been configured like thi
2004-11-16 15:44:44 EST: 32464 / 15729
Your download speed : 33244113 bps, or 32464 kbps.
A 4058.1 KB/sec transfer rate.
Your upload speed : 16107158 bps, or 15729 kbps.
I <3 Drexel
I have 3300/256, tested at 2467/239. Comcast in central california. My cable modem network is runnin on QAM256 on the downstream channel.
2004-11-16 15:46:24 EST: 297 / 4126
Your download speed : 304214 bps, or 297 kbps.
A 37.1 KB/sec transfer rate.
Your upload speed is much faster than down.. have you tweaked?
Your upload speed : 4225998 bps, or 4126 kbps.
2004-11-16 15:54:09 EST: 341 / 3421
Your download speed : 350128 bps, or 341 kbps.
A 42.7 KB/sec transfer rate.
Your upload speed : 3504013 bps, or 3421 kbps.
I just checked mine last night after I rebooted my router. It was just about what it is supposed to be.
2004-11-16 16:47:21 EST: 1443 / 400
Your download speed : 1478166 bps, or 1443 kbps.
A 180.4 KB/sec transfer rate.
Your upload speed : 410420 bps, or 400 kbps.
supposed to be 1.5mbps / 512kbps so I'd say it did mine okay
Same thing happened to me last time I tried from work. A pair of DS-3's are just a tad outta reach for that test.
Anywho, getting 4035/505 which is right where it should be. Cox HSI in Scottsdale, AZ. Advertised is 4megs down half meg up.
