DSL questions
isekii
28,578
Is it possible to have multiple modems connected to the single DSL line and combine the bandwidth ?
WhiteKnight77
472
Are you trying to share the connection? DSL is capped for speed so trying to use multiple modems shouldn't have any effect on it.
ILikeStuff
476
I highly doubt it. DSL works by modulating the signal at a certain range of frequency. I would think placing two modems onto a single line would interfere with one another
HappyPuppy
16,997
No, don't believe so, but you can have more than one modem connected to separate lines and combine them to increase bandwidth. I read it somewhere, forget where now.
XZeroII
12,572
Are you asking if you can connect more than one modem to a single phone line? Why would you even want to do that? If you need that much bandwidth (and have that much cash to spare), you should get a T1 or something. To answer your question, no. You can't do it. You would need two phone lines and 2 accounts. As I said, if you have enough money to do that, get a T1.
isekii
28,578
It would be one line .. but different plugs. i.e I have some kinda box outside where I can put upto 8 lines running into my home.
So if it's 1 dedicated line but split into 8 lines and just using 2-3 dsl modems connected to it.
Would you benefit from the speed increase by 2-3 folds ?
I heard from somewhere that DSL lines can be stacked... i wanna know if it's fact or fiction.
edit. Last time I had DSL they didn't require me to log in or anything I was automatically connected.
