When you say you have 5 IPs, do you mean that your ISP gives you 5 and your problem is getting the 6th? If this is the case you could have five of your machines connected to a normal hub (each machine with its own IP address) and then use the Internet connection sharing functionality of Windows on one machine and point your sixth machine at that one.
